·How good is the stock fuel system (injectors, pump, lines)? I read that the stock injectors are 330cc or something and they're good for ~400hp. At what points should you upgrade the injectors, pump, and fuel lines on an NA?
What injectors and fuel rails will work with the 2jz-ge? I know the injectors are high impedance, but you can wire in resistors to use low impedance injectors. And where can you get the resistors? MKIII?
For the fuel pump, the stock TT pump and upgrades for the TT will work, right?
Trying to get all the info in one place.
