Since i have had my car my fuel guage has never been right. I has fluxuated from full to empty and back and foward. I have changed the plunger and i have the same problem. Does anyone have any idea, what else i can check. Or suggestions. or what esle i can change?
David
in the trunk, under the spare there is a hole into the fuel tank. in the hole is a plunger that dips into the tank and when the fuel level changes and that is what gives sends the fuel height to the guage. i call it a plunger sorry because it dips into the fuel. it a piece of metal rod and on the end is a little cylinder containing air as the fuel is full it floats and as the fuel level goes down the plunger or the air cylinder gradually goes to the down position and all the inbetweens are the half tanks quater tank.
well i changed that thing and it still tells me wrongs readings. any ideas
