got boost???
how would i check to see if any fuel is leaking thru the injectors? what could cause a gas smell coming from the engine? scared of running lean gotta get it checked ASAP
Dr Wheelspin Rh.D.
With the motor off and the key in the on position, jumper the Fp and B+ terminals in the diagnostic block. You should hear fuel rushing in the rail and if there's a leak you will be able to see it by looking around.
got boost???
just did what u said...it seems to be a leak from the first couple of injectors....i can hear it but sounds like its leaking somewhere under the manifold? can't see any visible leaks...so what can i do to be sure?
