I have a question for those who have tuned either stand alones or piggybacks that actually have a fuel (injection or airflow) map. Not just adjustment knobs at certain RPM's. So basically, AEM, Emanage, Motec, PowerFC, etc...
When you tune a Supra with all the standard APU mods (single, fuel, exhaust, etc.) do you really only pay attention to tuning the mixture curve when at WOT, but at different boost levels? Say, create a low boost (pump gas) map, and a high boost/dyno (race gas) map?
Reason I ask is, i have read several times where it has been said that you really only need to worry about your air/fuel ratios while under full load and at wide open throttle. Should I care about and try to tune the map(s) for say a safe A/F ratio for those times I am at 75% throttle, merging on the freeway?
Any opinions or input would be greatly appreciated. Thanks.
