Ok so I have been battling this fuel pressure issue for some time now. I have done countless days worth of research and searching, to no avail unfortunately.
Car: 93.5 Supra, 6 speed, built engine, PT 6265 billet, AEM V1
Symptoms: Fuel pressure is perfect on initial start up (42psi with hose off and 38-39psi with vac line on) and the first couple pulls of the day. After the car gets warm, say 30-45 minutes of driving, the fuel pressure drops to around 30psi. AFR's become too lean.
Fuel setup is: BL fuel system, Aeromotive A1000 regulator, PT 880cc injectors, Dual denso pumps, Stock feed, additional -6 feed, stock return, BL fuel rail. Running a 8g or 10g power wire directly from the battery with an 30a inline fuse to the relay, using the factory + and factory - as both positives for the pumps. Pumps are grounded to the hanger and hanger is grounded to the chassis. I am still retaining the factory fuel pump ecu and 9v/12v operation and the fuel pump relay is wired into the output wire on the pump plug harness. I am using Cwtt's wiring setup.
This is what I have done so far:
2 brand new denso pumps from Titan
New aeromotive regulator diaphragm
8g grounds for the pumps
75Amp high current relay for pumps
Both fuel filters were new 3k miles ago
I am out of ideas as to why I cannot maintain fuel pressure. Someone suggested that I bypass the fuel pump ecu altogether and use the 12V mod off mkiv.com. In my research I have read that aeromotive regulators have trouble maintaining fuel pressure due to the heat generated by the denso pumps.
Thoughts?
Thoughts?
