Hi guys. In my '85 I'm running a 6M with a CT-26 Turbo. What fuel pressure should I be running if I'm using stock injectors? I have a Cartech RRFPR and according to their documentation, you need a minimum of 95 psi fuel pressure for 7 to 8 psi of boost. Well, according to my fuel pressure gauge my max pressure is about 80 psi. What happens is I can boost up to about 4 psi with half throttle. That's it. If it press the pedal down anymore, my boost stays the same and my a/f gauge jumps to the lean side. Should I be upgrading the fuel pump with a high flow unit? Or should I be looking at larger injectors? Any info would be greatly appreciated.
