Next time it wont start, turn it off and bang on the bottom of the fuel tank somewhat forcefully but not hard enough to dent anything. The goal is to shake the pump. If after that it does not start, get someone to do the same thing while you crank the car.
If either of those work, you most likely need a fuel pump. If not, it is likely an eletrical issue and we can go from there.
My first guess would be a bad fuel pump anyways.
