I have a couple question regarding fuel supply. I have a new motor with almost 1k miles on it and I want to make sure the fuel system is all set before I start to beat on it
Anyway, I have an Aeromotive pump that I power with 10 gauge wire from the battery and a Bosch relay that is triggered by the stock fuel pump wire.
My questions are as follows:
1) I noticed that the pump does not start to run until the key is turned to start. Every other car I've worked on has the pump start when the key is turned to on.
2) I noticed today while under the hood, that when I rev the motor from idle, the fuel pressure rises. Is this normal? I know FP is supposed to rise with boost, but I don't remember seeing it rise from blipping the throttle.
3) I notice from inside the car, that when I give it a little throttle, I can hear the relay for the fuel pump kick off and on.
Do I have this thing wired correctly? I'm thinking maybe I need to do the 12V bypass thing to the stock FP wire that is triggering the relay.
Any thoughts are greatly appreciated!
