Where can I find the floating device that tells how much gas is in my tank?? Do I have to pull the tank down??? Also where is it?is it electrical or mechanical
rly?If you go into the trunk and lift up the spare tire cover you will see a gray plate with 3 screws in the middle on the passenger side of the trunk. Once you take this off you'll see the top of the sending unit. Take the 5 or 6 screws off, disconnect all electrical lines and it will pull right out.
Yea it's right under that gray plate. Much better than having to drop the tank.rly?
hmmm, I've never looked in my spare tire storage....
I assumed that since you had to drop the tank for the fuel pump, you had to do the same for the sending unit.
Could be that the little plastic float has a leak in it, or something is bent.Yea it's right under that gray plate. Much better than having to drop the tank.
My gauge doesn't go all the way up to F anymore. It only goes between the F and 3/4 mark. It used to go all the way up. Is this the sending unit or gauge? The current unit is out of another supra, but it worked for awhile. Any ideas anyone?
sweet...i'll check it out.Could be that the little plastic float has a leak in it, or something is bent.
There is no way that floater can develop a leak, or the the arm being bent. Explain how that could happen. I would like to listen to your theory.Could be that the little plastic float has a leak in it, or something is bent.
This post...![]()
lol, I almost spit a little coffee on my monitor
