1 - 10 of 10 Posts
· i <3 supra
Does anyone know what connectors are what on this harness, and what will i need to hook it up to my 86.5 n/a supra..........
thanks!!!
thanks!!!
#2 controls the AC. There are 3 or 4 wires I believe. two of them are not used because they are for the speed sensor on the AC compressor. Unless you move over the AC computer, you will only need the AC pick. That wire should run to the EA2
It sucks that you got a hacked power supply harness or installation would be a breeze. You will ne #3 and #2 and then you are going to need the to wire in the plug for the radiator plug. I know a guy that got one from a camry that works. It is plug and play for the most part if you have the whole pig tail but you are going to have to wire everything in to your fuse box.
This is true.
I moved over the EA2 connector, temp sensor for the 1JZ alternator, as well as the battery connections without tearing it up. I had to pull apart the harness to get out all of the 7M automatic wiring for transmissions and fans. But, it was a very clean installation.
1 - 10 of 10 Posts
