1 - 2 of 2 Posts
89targa
I have a 91 and the dome light, ignition light that surrounds the key on the steering column and the light that is on the drivers door where you put the key in to open the door will light up together and slowly fade out together when it is turning itself off. Mine has stopped working completey. Where is the fuse that runs this?
The dome light itself will work only it you push one of the buttons by the light. But when you hit the factory unlock button on my key ring, it used to light up the dome etc. so getting into the car at night was made easy. I can not seem to find it.
It's only the beginning..
There's a relay near the fuse block that controls that, if cygnus was working, I'd give you the linky...
1 - 2 of 2 Posts
