1 - 15 of 15 Posts
· JZ Enthusiast
Guys ive searched for this but there is no subject about it !
Anyway i am about to install NGK Vpower Platinum and Iriduim i know both of them is good but i dont know which's the best !
Anyway my issue is how would i know HOW MUCH gap size I NEED TO do on thoes models ?
How do u guys know the best for stock DENSO IRID is .27 gap ???
Just need the Infos
thanks ..
I got the NGK Iridium 4919s. They are supposedly for an NA, but the only difference between the NGK Iridiums for NA and turbo is the spark plug nut size, and the turbo plugs don't fit in either car...NGK=dumb. The plugs are good though. They are gapped correctly out of the box I believe. Even if they aren't, my car runs perfectly and I did nothing to them.
for some reason my PLATS burn out quick, im runnin 10 lbs of boost. Dont know how many miles, my speedo doesnt werk, but takin it that i drive my car hard even single time i drive it...that may be the reason.
i dunt kno about the gap...i just use the gap that come in the box. but if memory serves correct..i think .28 is the gap...can anyone verify?
Just get the Iridiums I mentioned above, they last a long time at high boost (I'm running 15psi). The gap is correct on them from the box.
wrong. platinum and iridium are some of the hardest metals on the earth...little chance you can scratch the coating off. HOWEVER...it is a BRITTLE material, so if you gap them, then move them again...they might break right off.
That is what i thought about these metals....I believe mine said to have the Gap set at 42....I am guessing but there was a # 2 at the end.
if I find the specs, ill let you know Bahraini
1 - 15 of 15 Posts
