1 - 12 of 12 Posts
A friend and I recently put new plugs in my car and gapped them to .042. I have seen everyone else posting that they have their gaps at .032 and I began to wonder if I should change mine. He says .042 is what he has always gapped all his plugs to on his supra(s). :scratch:
What car do you have Turbo/Non Turbo?
If it is turbo you would want it .032 if it is running lower boost ie. 13psi or lower with stock CT-26
.042 is N/A territory.
Bobby Ali
BA
Turbo (CT26) with the boost up. I have an intake and an open 3" downpipe. He drives an N/A so maybe thats whats up...
EDIT: :madjerk:
Wingless by choice.
I actually said thats what the book called for, which it is. I haven't had the silver car for a long time and I didn't put those plugs in it when I DID have it. :)
Dr. Jeff Lange
Gap for 7M-GTE is 0.031", 0.043" is 7M-GE spec.
Supranian
I think I actually gapped mine at .029 (Turbo) since I saw this somewhere on the forums.
what would jesus drift?
i have mine gapped at .025 i was having problems at a larger gap, thougt it culd have been user induced..
smaller than stock setting is usually best for higher boost on stock ignition.
That gap is to big.
Personally I wouldn't re-gap plugs once they have been used, buy new ones.
Now with 0JZ
Why is that? I gap plugs all the time after use, especially when my brother steals the Iridiums out of my father's car so he can go to the track.
1 - 12 of 12 Posts
