1 - 9 of 9 Posts
Eclectic
LOCK Thread! Parts and prices for reference only
OLD THREAD. PARTS ARE GONE
Performance parts:
NEW Eagle forged H-beam rods $400 SOLD
NEW Probe forged .040" pistons w/Total rings $350 SOLD
USED ARP head bolts last torqued to 72 ft-lbs $50 SOLD
USED AEM adjustable cam gears $150 SOLD
Old school greddy TT w/harness $65 SOLD
Stock parts:
87 GTE engine harness $100
87 GTE MT ECU $50
87 GTE 5spd dash $35
HAC sensor $20
CPS $50
Coil pack $50
Ignitor $40
Stock AFM w/electronics $50
Stock exhaust manifold $40
exhaust mani heat shields $20
PCV pipe $10
Stock CT-26, good cond, normal wear, cracked wastegate port. $150
CT-26 stock elbow $10
O2 sensor $15
Stock oil cooler and mounting brackets $15 SOLD
GTE oil filter housing $20
87 stock intercooler $75
87 stock intercooler piping, fair condition $40
3000 pipe $15
Stock BOV $15
Intake manifold, upper $40
Intake monifold, lower $35
VSV fpr $10
vsv hardline manifold $10
trottle linkage $15
throttle body $30
TPS $45
87 knock sensors $50 SOLD
GTE pressure sensor $10
T-stat housing w/87 sensors $45
440cc injectors $60
Fuel rail $30
stock FPR $15
Stock CSI and lines $20
stock FPD line $10
GTE fuel pump $45
Stock 87 block $35 SOLD
.030 block, machined deck and timing cover $35
stock rods (2 sets) $50 /set
stock pistons $50
crank, needs polish $50
oil pump driveshaft $15
oil pump gear $10
timing gear rear plate, lower $30 SOLD
timing gear front plate, lower $20
timing grea rear plate, upper $15
timing dear front cover, $25
stock cam gears $15
stock cams $35
rear end plate (trans cover) $15
rear crank cover $15
flywheel cover $15
87 motor mounts $25
Set up cam shims and buckets $50
Stock flywheel $20
Stock pressure plate w/bearing $25
release fork $45
driveshaft, good carrier bearing $50
brake pedal assembly $30
clutch pedal assembly $30
Trans cross memeber w/bolts $20
Stock shifter $30
Speedo cable (for 5psd swap) $30
Trans wing brackets $15
87 Lip with mounting hardware $50
87 fogs $30
87 turn signals $30
headlight jacket trim $30
headlight motors $20 ea
87 maroon mirrors $40
Stock rims w/all season tires, lots of thread left. $150
Slow!
If the coil pack is still available, could you do me a favor and check the resistance of each of the packs as shown in the diagram I posted? Mine are out of spec and I'd like to replace them.
I'm also interested in pictures of the lip and mounting hardware.
Thanks!!
1 - 9 of 9 Posts
