When I fill the car up, the gauge is almost at half a tank, and slowly drops as I drive, actually, seems to drop a bit fast in relation to my last car, then just burrys itself on E for the next 200 miles or so. Never seen the low gas light come on, but never put anymore then like 12.5 gallons in it either, I fill up all the time to be safe about it.
Also, Oil pressure gauge dosnt work (sometime when I put the key in, it would jump just very slightly, then if I tapped on the plastic covering the gauge, it would go down more and more with each tap :wtflol: ), changed the sending unit and still no go, so i think the wiring or something maybe? I'm gonna swap out the gauges in a week or so, so what should I look for when everything is apart?
