I bought a fuelab power module 92902 intank fuel pump which flows 190 gallons of fuel an hour. I drilled, and cut the stock collar of the tank where original pump was bolted in, and installed the 92902. The pump sits an inch below the stock baffles.
To solve this issue I bought a sump to weld in under the pump.
I figured if I cut a hole wide enough I could drop the sock, and pickup tube from the power module into the sump.
The bottom of the tank directly under the pump would now become the top baffle of the sump. The pickup tube, and sock would drop into the sump which would provide continuous fuel for the pump under all conditions.
I already have the pump it's not going back so who thinks this is a bad idea. Wreckless?
The picture with the sump placed directly in the center is where I proposed to put the sump to be utilized only as a trough to sit the pickup tube and sock into.
I figured the Bottom of the tank becomes the top baffle keeping fuel in the sump during all conditions.
