1 - 12 of 12 Posts
2JZ-Phantom
Hey guys where can I get a gasket to fit the oil return on the oil pan for NA-T? Thanks
a stock TT turbo oil flange gasket from toyota will work fine.
2JZ-Phantom
Thanks, Im tried that but it must have been the wrong one since I did not fit. Do you have a part number by any chance?
Hardtopper
I just used some sealant without a gasket... works like a charm couple years later...since I dont have to take it out for anything
you can always get the gasket material from an auto store and cut it out yourself.
2JZ-Phantom
Cool, I try to combine sealnnt and gasket because I have a stupid leak. This will be the third time I have to take my setup down to fix this thing. You think on top of the sealant and gakest if I cover the with JB weld it will stop the leaking?
dont JB weld it......if anything remove the pan and have someone tig weld the flange to the pan. Never worry about a gasket after that.
2JZ-Phantom
Cool thanks, do you guys if there is tap big enough to just tap the oil return hole itself?
King of the NA-T's
Use permatex *the right stuff* as a liquid gasket. The stuff is magic. Just make sure you have all the oil wiped off so it's a nice clean surface.
2JZ-Phantom
Discussion Starter · #10 ·
Sounds good Dave. Do you think I can combine permatex and a gasket? I get it at any auto store? Thank again.
King of the NA-T's
I wouldn't bother with a gasket, just use *the right stuff*. Most any auto parts place should have it. It comes in a aerosol can that sprays out sorta like those cheese dispensers for crackers.
DaveH
1 - 12 of 12 Posts
