I fitted the motor some weeks ago and now that i have all hoses conected the car has developed a seriuos leak on the water pump, its from the lowest screw that the water is coming out, i first thought, that it had gotten loose but even i applied more strength it keeps leaking.
Probably the fuel pump got hit when i fitted the engine in the bay so...
Did i brake the gasket or did i destroy the water pump, i have not seen any signs of external damage, but the water pump and all prodtruding from the engine took some hits maybe even preasure so I would like to hear some opinions on these. :rolleyes:
I've had mine break. When it goes, it tends to destroy a whole lot - the fan will flop around on the front and eat your radiator shroud, and likely bend the hell out of your radiator. All your coolant blows out past the bearings, and your engine overheats.
For the $75, you can't buy an easier way to sleep at night.
