2damaxsupra said:anywhere from 80lb-90lb should be good depend on which lub u use, if u r using the lub that comes with the ARP set (i think u r only suppose to torque it down to 80lb with the special lube)
You should clean out the threads too with a thread chase to get accurate torque readings. I recommend going to ARP website and reading their technical info.KINGPIN33 said:lube??? what is this lube i am suppose to use? I got them ARPS used... please help.. i'm still learning..
Rajunz said:You should clean out the threads too with a thread chase to get accurate torque readings. I recommend going to ARP website and reading their technical info.
