1 - 3 of 3 Posts
Automotive Technician
i am only able to do things a little bit at a time and i want to get a boost vacuum gauge. there are two types available. one comes with a map sensor and the other a believe yo just hook up to a vacuum line. they are the autometer cobalt series. which would be the better type map sensor gauge or vacuum line?
either one will work pretty much the same because the both run off of a vaccum line.
either one you will have to "t" in to an existing vacuum line or its own vacuum port if you have a distribution block. the only difference is for the map sensor one you will only need to run wires from the engine bay to the guage. the one without you will have to run a vacuum line all the way to the guage.
go with the vacuum line one it less work to hook up just make sure you t off from a line that see's boost buddy of my made that mistake took him forever to figure it out but easy can be nice.
1 - 3 of 3 Posts
