In front of you
What else is needed for Apexi EL series mechanical gauge for installation and how much will i have to pay for anything that is necessary. It si just the gauge, no wires or anything that plug into the gauge.
Hi,
If its a mechinical gauge you would need a barbed fitting, some vaccuum hose, and a vaccuum tee......
You should have 2 wires only (for the lighting)...those you can splice into your ashtray light or something)....You pu on the barbed fitting, use a hose clamp to make sure it is tight on there....then run the hose through the firewall to where you wanna record boost from. and tee it into that location.
Done!
Asheesh
