1 - 10 of 10 Posts
Does anyone make one. I need to install a peak and hold gauge, but don't want to change out the rest of my guages which are 52mm. Would like to put them all in the same pod. Any suggestions? I already have an egt in the clock space, air/ fuel, boost, and oil in the pillar. Does anyone make a 52mm peak and hold if its a no go on the pod? :dunno:
Still Sportin' the Twins
1st Lieutenant Team BEYAW
yeah, just like David said, just take a dremel and shave of the edges of the 52mm gauges and the 60mm will slide in. That way, if you have gauges of different sizes, you can just trim the holes you need to
1 - 10 of 10 Posts
