Turbo Member
I have a BPU MKIV TT and just got a defi system with all the sensors installed. Now that I can see what all the vitals of the engine are I need to know what is normal. EX oil pressure, oil temp, coolent temp, EGT, fuel press, boost. and any others... Thanks For the help!!!
My oil pressure after car is warmed up sits at 1.5kg/cm^2, which equals about 21psi, and temps are at about 95-100C.
Hope that helps.
-PHu
Turbo Member
After I heat up my car the oil press drops to close to 18psi when I am sitting at a red light. Should I be concerned. The eGT runs around 5 andH2o Temp and oil temp have been as high as 201 h2o and 211 oil. Do these sound right???? Thanks Andy J
93tt Auto BpU
93na Stolen Atlanta Region. 5 speed baltic blue silver window tint If seen email 4048865725
oil pressure will vary depending on the weight of the oil you put in
your vehicle.
so yes, 18psi is fine, 15psi would be fine too, but only during idle.
EGT sounds fine. 201 and 211 are in F, he expressed normal
values in C.
100C is 212F, so your temps are fine.
When the oil heats up it will thin out and you will lose pressure.
