Okay everyone, just checking to see if anyone is in the market to produce this. The sources are available if there is enough interest. The manifold will be a stainless steel, tubular T4 single turbo manifold for the 1jz. There will be two ways to order it. You will be able to order it without a wastegate flange welded to the wastegate dump tube, or with your choice of any waste gate flange. Pictures of the first prototype will be up later on this evening. The price is still a little bit negotiable, but shouldd be very close to the following estimates:
Manifold WITHOUT wastegate flange: 775.00
Manifold WITH choice of Wastegate flange welded: 850.00
Prices do not include shipping. The manifold will be polished for a very nice look. Again, pictures will be up later this evening. Chris Hamilton (HAMSMKIII) and I will be producing this. The pictures are of the test manifold itself bolted to Chris' head with his T4 attached. There is a picture that shows the WG tube touching the motor mount. This was encountered during the testfit and we will be cutting and changing the angle so as to not touch it and be a perfect fit. There will be more pictures added of the manifold off of the motor. Thanks for the interest!
