most of you may have read my problem with my clutch, and how i blew 6 pressure plates (both stock and aftermarket), so i gave up, and i want to go auto so i can at least drive hopefully this season.
is that all i need:
2jz flexplate
2jz or 7m torque converter?
2jz auto bell housing
7m a340e
ma70 a340e driveshaft
some stupid wiring to the ecu
thanks
Shaq who?
if your interested I have a a340e that I got with my Ebay engine/tranny combo and i'd be willing to let it go for cheap if you'd come pick it up but your kinda far away
haha, yeah, i probably would've picked it up, but you are quite far away.
anyways, in regards to the parts required, i'm pretty sure you can't use the 7m a340 tranny as it requires a kickdown cable that the jz tranny bypasses by using 2 extra solenoids on the transmission.
now, the only question then is the torque converter and the driveshaft. can the 7m or the jz torque converter work, and will the ma70 auto driveshaft work?
