1 - 3 of 3 Posts
what should i do to reduce the final gear ratio of my supra?
Reduce...? You mean make your final gear longer or shorter. I'm assuming you mean shorter. Change your ring and pinion in the differential is what needs to happen. This can be accomplished multiple ways.
1. Change just the ring and pinion by pulling apart the diff.
2. Change the diff entirely with one that already has the desired ratio
1 - 3 of 3 Posts
