1 - 9 of 9 Posts
Finally up and running!
I currently have the NA 4.30 rear end (unfortunately non LSD but I haven't had problems hooking on the street). I will be going to Englishtown and Lebanon Valley a couple of times this year, first on my 245 radials with the boost limited to 14 psi(~400whp) and will be attempting to get used to the track, as I have never been before. I have launched my MKIII on the street when it was still a stock twin 1jz (BPU ~310whp) and it hooked from a harsh fade from 4200.
My setup now is an XS power T3 manifold with a Holset HX35w (compare it to a gt35r, the hx has less power potential but a faster spool). An Aristo ECU, 440cc injectors, walbro, 12x24x3 IC w/ 2.5" hardpipes and an SAFCII.
The thing is, by the end of the summer, I hope to be on some 26/275 drag radials on a spare set of Cobra 17's. When should I switch to a lower gearing, like a 3.91 or a 3.73. Should I wait until I am hitting the rev limiter at the 1000' mark, or should I say screw it and swap it out now. At rev limit (6700) with a 26" tire in 4th, I will be topping out at 120.
Thanks in advance guys.
KBR
get yourself a good LSD and stick w/ the 4.30 rear end. thats a good combo for drag racing, specially for the MKIII.
aite, peace.
Not so boring anymore
Swap it for the LSD now. An open diff will do you no good.
Is this on a 1jz??? THe rev limit is 7200 RPMs... ain't it??? lol...
aristo ecu has a 6700rpm rev limiter.
i got 4.30 LSD nasty out of the hole but alot of shifting the shifting part dont bother me, since i changed to poly bushings the car feels 10x better
.373 lsd, but definalely use smaller rims, 17's aint gonna cut it, try to get more side wall. 60 foot will love it.
shawn
1 - 9 of 9 Posts
