1 - 2 of 2 Posts
Toyota 2JZ-GTE 6-Speed Flywheel
Toyota Flywheel Bolts
Toyota 90560-79001 Spacer
Toyota 96152-00500 Snap Ring
Toyota 31264-14060 Spring Washer
Toyota 90560-50001 Spacer
Toyota 90206-12006 Wave Washer
Toyota 90520-75001 Snap Ring List
Toyota 08885-01306 v160 Oil
Toyota 90311-90006 Rear Main Seal
Toyota 90080-31027 Input Shaft Seal
Toyota 90080-31029 Tail Shaft Seal
Toyota 90080-31032 Shift Shaft Seal
i copied this from his sticky about v160 parts....hope it helps...
i ordered alot of stuff for my 1jz and everything was awesome dealing with Jeff
V160 CLUTCH PARTS
00602-31201-010 TRD single clutch kit ( DISCONTINUED)
13450-0w011 6spd flywheel list 622.76 cost 445.54
90910-02115 fly wheel bolts list 9.92 cost 7.09 ea x 8
31204-14060 fork list 66.48 cost 47.56
90311-90006 engine rear main oil seal list 35.10 cost 25.11
31250-14190 oem disc list 81.72 cost 58.46
31210-14170-84 oem cover (re-man)list 153.17 cost 109.42
90363-12002-77 pilot brg list 9.36 cost 6.70
90903-63001 t/o bearing list 66.82 cost 47.80
90119-08079 cover bolts list .49 cost .35 ea x 6
For the hub:
90560-79001 spacer list 2.40 cost 1.71
96152-00500 snap ring list 2.72 cost 1.94
31264-14060 spring washer list 3.06 cost 2.19
90560-50001 spacer list 6.03 cost 4.32
90206-12006 wave washer list 1.60 cost 1.14
90520-75001 snap ring list 3.06 cost 2.19
For the Trans:
08885-01306 v160oil qt list 48.48 cost 34.69 x 2
90080-31027 input shaft seal list 12.76 cost 9.13
90080-31029 tail shaft seal list 21.43 cost 15.34
90080-31032 shift shaft seal list 6.64 cost 4.77
1 - 2 of 2 Posts
