1 - 3 of 3 Posts
anyone know if a getreg 6 speed will mate up to a 1jz motor? is the block pretty much identical to a 2jz? just curious if its been done.
Ronin
matches perfect, use a 6 speed clutch, a 1jz flywheel, good to go...
Don't need a 1JZ flywheel, 2JZ flywheel works 100%. Infact you will HAVE to use it for the stock 2JZ clutch to to the dampers in the flywheel.
1 - 3 of 3 Posts
