1 - 10 of 10 Posts
Vendor
Curt, could you give me a quote on these parts? Thanks in advance, I appreciate it.
Glass Headlights (mkiv)
Valve covers for the 2JZ-GTE
Getrag Crossbrace as well. The part that supports the rear of the transmission, probably 8-10 inches wide. I believe it has a 3 inch or so rubber piece on top of it. (if that is seperate, I'd also need the quote for that)
X-brace would be going to zip 32825 and headlights and valve covers would be going to 20877. Thanks again.
/Mark
glass head lamps + 208.00 ea
11201-46040 VALVE COVER LIST 193.03 COST 142.74
11202-46021 VALVE COVER LIST 196.31 COST 145.16
12371-46110 TRANS MOUNT LIST 70.48 COST 52.12
57255-14231 X MEMBER LIST 169.11 COST 125.56
Vendor
Curt, the trans mount, I've heard there is a TRD upgrade for it. How much would that run? Thanks again.
Vendor
Curt, can you give me a shipping quote to zip 32825 for the head lights, valve covers and cross brace/mount?
Is the TRD still on backorder? Any idea when it will be available?
Thanks again.
/Mark
Vendor
Curt, also, if possible, can you give me a quote on an entire passenger side door for the MKIV?
I'll let you know about the other items shortly.
Vendor
I'd probably need all of the parts to be honest...sheet metal, inner liner, arm rest (don't know if that's part of the inner liner), and window control/motor, shell/latch.
  • Like
Reactions: IdealSupra
1 - 10 of 10 Posts
