1 - 13 of 13 Posts
SupraCop
hey guys
i am working on my car right now. i thought i broke the bolts free last week. i heated them up and loosend them. today i am putting on my exhaust and dp, and when i went to take the bolt off the nuts did not seperate from the bolt.
the whole nut came off too.
how big of a problem is this. can i just order a new bolts for the turbo manifold or did i just screw it up?.
I already have new nuts but i didnt think the bolt would come off too.
thanks
matt
SupraCop
so nuts and bolts from homedepot are okay or should i buy that set from mvp.
also anyone have two drill. it is the lowest one out of the three. i am going to continue
and see if i can get the stock pipe off. from there i will be able to play with the bolt a little more
i'll let you know any advice will help
Those are studs you are dealing with, not bolts. I hate those lock nuts toyota uses. Get new studs for the two that came out if the threads are ok. You will have to drill out the broken one. I wouldn't try to retap it. Just drill out and use a stainless bolt and nut instead of a stud. Stainless from home depot, lowes or hardware store is fine. I usually replace hardware with stainless when I'm working on things. Will save headaches later since the stainless won't rust like the factory stuff. And I usually put never sieze on difficult bolts like exhaust. Stainless lock washers would be a good idea too.
SupraCop
Discussion Starter · #10 ·
the bolts i got.
10 mm 1.25thread. thread fits but going into the turbo man. it is not threaded all the way. should it just go until it locks and tork it that way
or
should i go 8mm and do a bolt and nut straight threw.
1 - 13 of 13 Posts
