1 - 20 of 20 Posts
Captain Cool
well ive decided to do a bolt on turbo conversion to my 93 supra na but i need some help. im deciding to go with the Nonturbo.com kit, whch i believe is the DaveH kit, if im not mistaken. (my ideal range for horsepower is 380-450, if you know any kits out there better to get to my goal, PLEASE let me know). Anyways, ive been reading the posts of other owners for about 2-3 months now and i have searched ALOT, but i just wanted to make sure of all the things i need...please let me know if im missing anything (even if it's something really small but part of the conversion).
-The turbo
-exhaust
-intake
-oil lines
-upgraded fuel pump
-upgraded fuel injectors
-intercooler kit
-apexi s-afc or greddy e-manage
-blow off valve
-headgaskets
-wastegate
-wastegate downpipe
-midpipe
-downpipe
-cast-steel manifold
-high performance clutch
-boost controller
-turbo timer
-and all bolts from the kit
again, if i am missing something, or dont need anything thta is listed up there, PLEASE let me know. i really really appreciate it...
Captain Cool
cool thanx...so is there anything else im missing or dont need? or is there a better and/or cheaper kit out there???
pirates like cookies
you'll need some IC piping... ARP head studs if you are indeed changing your headgasket... and also, the afc+upgraded injector combo would probably work better if you had a vpc, or at least a lexus afm... turbo timer, you can do without it for a little while, it won't do too much damage... highly recommend a boost gauge though
Captain Cool
verge, i tried searching for it, but what's a vpc afm???
Captain Cool
Discussion Starter · #11 ·
yo im learnin just like everyone other fuckin person it be nice if you could just help me out thanks
Wingless Hardtop Moderator
Well... try reading like every other person to.... follow along over time and you'll catch on.... everyone had to start somewhere, after about 5 months I've got it down pretty good.
Captain Cool
Discussion Starter · #14 ·
ya i have, ive been reading up on na-t conversions for awhile and seeing what people are doing and looking at all diff. kinds of kits, i just need help here and there u kno
but thanks all for the info
blur2ed.com
personally, researching NA-T conversions since i got my NA ( 1 year), im still somewhat confused on a VPC, and exactly what it does / how it works. Good luck TaBoo
Captain Cool
Discussion Starter · #16 ·
thanks blur2ed ya well after, i went on other websites to find more info on vpc and what i can make is that it is a fuel computer but anyway again please let me know if i need anything else for the conversion or if there is anything that i dont really need thanks much
The VPC deletes the factory airflow meter and converts you to a speed density metering system, it has pre-programmed fuel maps depending on what chip you have in there. It took you a year to find someone to explain that to you?
If it helps you at all in your buildup check out the link at the bottom of my sig.
- Jon
King of the NA-T's
A little more detail on the VPC for those who care.... the VPC estimate's the air going into your engine based on the intake air's temperature, and the pressure or vacuum in your intake manifold.
The Stars At Night
does anyone have specs side by side comparisons between the nonturbo.com upgraded turbo kit and the powerhouse racing stage 2 kit.....which is better....sorry i dont mean to take over your thread, but both these kits are coming into my mind as possibilities also
Captain Cool
Discussion Starter · #20 ·
no no by all mans, i'm a bit curious myself...
1 - 20 of 20 Posts
