1 - 4 of 4 Posts
Ok I need to have some bushings (lower control arm) pressed out
Anyone have any suggestions on where to go?
:sadance:
brian_k03 said:
Ok I need to have some bushings (lower control arm) pressed out and apparently 20 ton presses are not going to cut it. I was told that a machine shop will have large enough presses to get the bushings out.
:sadance:
Brian,
I found a machine shop next to us. Call me and I will fill you in.
JPI
EFI Certified Tuner
If not getting overcharged is important to you, I've had good luck with these shops:
Automotive Machine & Supply Inc. ( www.automotivemachine.com )
^ these guys have a lot of supra/2j experience and really know their stuff and they're very honest and care about helping you out whatever your budget may be.
http://www.planoautosupply.net/
^ this is also a very good local machine shop that does basic oem machine work for lexus repair shops...they're not as knowledgeable in turbo cars or doing aftermarket 2JZ stuff though.
1 - 4 of 4 Posts
