I have a LHD Supra and installed the T56 Magnum F. I had trouble with the template. I printed it at 100% and made sure I had it oriented right and cut it out carefully. To me, something isn't right with it.
Here is the template cut out and held underneath the trans panel. I have the paper template flipped upside down. The "This side up" should face the cover panel. I'm only holding it like this to emphasize that the front edge of the template when held upside down, is parallel to the front edge of the tunnel cover.
Now look what happens when you have it oriented the correct way. The front edge of the paper isn't parallel with the tunnel cover. It actually pokes out past the edge.
So I think his template is mostly right, except for the front edge. I think it is slanting the wrong way. I sent him pics weeks ago when I encountered this and he said he was going to look into it. Anyways I cut my tunnel using his template and the front edge was wrong
I had a gap on one side that the cover wouldn't cover. I ended up welding a lip onto the Grannas panel.
With the lip it hides the miss cut. It also makes it more secure as the seam sealer gets sandwiched on the front now just like it does on the back. This pic is just from a test fit. I removed it and repainted it before installing with seam sealer.
If anyone is reading this before cutting their opening out, I'd also recommend cutting 1/4" more on the drivers side. That nut that gets cut in half... Cut the line so you don't see the nut. Otherwise the edge is extremely close to the red base of the tremec shifter. The half a nut hanging down on mine actually hit it. I ground off the nut so it didn't stick down, but I should have cut off 1/4" more material. I will if I ever pull the trans down.
The final thing that bugs me is the shifter boot. He uses a Mr Gasket 1651 boot which is angled. The shifter sits up straight. Because it's angled it causes the boot to buckle in the 2/4/6. I think somewhere out there is probably a better boot that isn't angled that would work better. I think moving the boot back 1/4" would also make it more centered. What he has technically works though. Also I tore my boot just sliding it on. The edges of the shifter extension are rounded some, but they are still kind of sharp. I ended up filing mine down some more and wrapping the base with some electrical tape. I also ordered two new boots (one to replace the one I tore, and one to have as a spare).
I had the T56 Magnum before going to the T56 Magnum F. They were both a little noisy, but I think that is more because of my unsprung OS Giken clutch. I put some thermotek heat/sound mat on the top side of my tunnel and that helped quiet it down some. If any part of the trans is hitting the tunnel, it will amplify the noise. When I had the sikky setup I had to grind the heads down on the sikky bolts because they wanted to hit. With the Magnum F the reverse lockout solenoid was still rubbing even though I had dented it some. I put a block of wood on the passenger side of the tunnel to keep the trans from moving that way, and then really put a 1/4" dent on the other side with a pry tool. The reverse lockout has plenty of room now. I have some Tremec HP MTF fluid coming too that I want to try.
All in all, I'm happy with the trans. The Magnum F feels 100x better than the sikky setup. It is perfect. No wobble, smooth shifts. I've never driven a v160 car, but I have driven other 6 speeds (3000gt vr4s, sti, regular T56 in my rx7...). I'd rate the Magnum F a 10/10. I can't imagine it feeling better.
The tunnel cover and boot setup I'd rate a 6/10. It technically works but could use some improvements. I think Joel is more race oriented and sometimes underestimates how OCD some of us are. I'm buying an oem 6 speed trans tunnel just to keep in my parts room. That way worse case I could always cut the entire thing out.
My clutch I'd rate a 7/10. The pedal feel with the OS Giken is great. It's not hard to push in. It also holds power well. However its tricky to get use to. Avoid stop and go traffic in flip flops. It's also noisier than I'd like on decel or lugging. The mat helped ,and I just downshift if it's being too noisy. I'm at the point where I wouldn't mind trying a different clutch with springs. However clutches for these cars are around $2k. I wish I could try one before buying. If I have my trans out again I may add a later of thermotek wrap under the tunnel. I did that on my rx7 (layer on top, layer on bottom).
