1 - 8 of 8 Posts
Ok, can anyone post the part # for the greddy 3 row FMIC?
Also, will this bolt right up to the stock twins?
Also, can you weld on a BOV?
Single Turbo
just go to the forums sponsor sites (mvpmotorsports.com, WOTM.com....etc) or the for sale section in the forums for a greddy 3 row. I saw a brand new one the other day. Yes it will bolt right up to the stock twins and yes you can weld on a BOV.
BoostedBreakDancer
FYI some people have surging problems when they hook aftermarket BOV to stock twins
i think its because the MAF already calculated fuel for the air that you are releasing back to the atmosphere or somthin like that stock bov vents into engine
Part # 12010026
also unless ur running a VPC or MAP ECU or whatever u want to use to get rid of the MAF you will need to recirculate the BOV back into the intake BEFORE the MAF. HKS sells these recirc. kits
Fan of Stock Twins
I think you need to be careful with Greddy part numbers....from the research I've done, there appears to be a 3-row kit with piping for the stock twins, and a different 3-row kit with piping for their single turbo upgrade kit. Both appear to have the same core assembly, power steering cooler relocation hardware, and coolant overflow bottle.
Part #12010026 (from Greddy website) is for use with the Greddy turbo.
Part #12010409 (from MVP.com) is for use with the stock twins.
Intercooler core for both is the 23R, but piping may be different. Maybe someone else knows first-hand whether this is truly the case.
Greddy T78
And now there is a new released greddy 3row kit....
Dont know the differance, just know they have a new one....
// André
Discussion Starter #8
hmm so that one on ebay looks like its for a single turbo?
1 - 8 of 8 Posts
