1 - 9 of 9 Posts
Fat Guy in a Little Coat
I have a t61 with turbonetics cast manifold and greddy 3 row ic. Does anyone make a pipe that will adapt that will allow me to use the piping from the three row to mate up to the single turbo?
MDoe8 said:
just make your own... [/QUOTE
I dont have a pipe bender. I can have someone in town do it, but I was just looking for an easy fix. Get off the computer Dohack and put your car back together.
PM sent. ]
My tranny isn't back yet :(
I just hacked up my stock turbo to ic piping and made them work
-Mike
i have the same set up as you. I modifeied my existing 3row piping to work like the 4 row i just cut peices to length and had a bead welded around the pipe i cut so the silicone coupler could seal up....just get creative and you will solve your problem with what you have...
edit: I did use a 90 bend of mild steel that should be readily available at any auto shop i would recomend a semi parts plcae they are cheap usually more helpful/knowledgable and have a large selection
for anyones future knowledge, Kean at Boost Logic sells this pipe along with the 90 elbow for about 100 bucks. Saved me time and money.
1 - 9 of 9 Posts
