1 - 3 of 3 Posts
Gone Fishin
I recently installed a 61mm turbo onto a Ebay manifold, I am trying find out if the pieces from a greddy 4 row I/C will work from the turbo to the inlett of the I/C. Pics would be greatly apprec. if avail.
it should work. The only thing you might need is a silicone 90 degree bend so you can cut and fine tune the angle from the turbo to the first IC pipe.
Exclusive 1000+ Post Club
Did the turbo comes with the elbow piece already welded on? If so, you may need to cut it and reweld it so that the angle is correct for fitment like ScrewDrvr suggested. The best way to do so is to take the car to a welder, line EVERYthing up and then have him mark it off and do his work. That would be the ideal situation.
Joe
1 - 3 of 3 Posts
