Put it in over the weekend and i measured continuity with a meter after splicing it to see if a signal would make its way to the timer and it does. The timer doesn't kill the engine when the e-brake is released. Other than that it works.
I'm not using the rpm function cause just easier to use the presets than install it. Does that wire need to be grounded (purple on timer)? Just in case I want to install the rpm function what color is the rpm wire off the ecu? I have the electrical wiring guide for the 97 supra its just a pain in the ass to hunt it down.
Thanks in advance
R-
Thanks in advance
R-
