1 - 3 of 3 Posts
I am quite pleased with this little trick controller, Incredible quality, awesome mounting method, does exactly what it is supposed to do. 4 clicks = 1psi. Also have a AEM true Boost EBC partially hooked up, will deal with that one later when I have more time...lots more time..:-(
Turned the GrimmSpeed controllers big knob 8 clicks in, it made 2psi more while data logging. Running on E85 <------CRANK UP THE BOOST....woot skeet Yea !! simple as that !
Copy pasted from Grimmspeed.com:
Superior Range with Ultra-Fine Resolution!
* Over 250 Way Adjustable
* Heavy Duty SST Dual Ball Detent System
(Clicks with each turn for active feedback)
* Laser Etched Scale and Labels
(Easy to read and repeat precise adjustments)
* Extra Long Travel Spring
(ONE spring, no need to switch Springs)
* Superior Range without Sacrificing Resolution
(0-60 PSI Capabilities with Ultra-Fine adjustments)
* Universal Mounting Solution
* CNC'd From Weapons-Grade 6061 Aluminum
(Incredibly Durable and Ergonomic
Welcome to the next evolution of boost control, The GrimmSpeed Manual Boost Controller. Introducing the most refined Manual Boost Controller available on the market. We spent over a year working hand in hand with Tuners across the country to devolop our MBC. Our Manual Boost Controller allows you to raise the OEM boost levels in a quick and efficient manner. Adding the MBC will result in Quicker Spool Up, Quicker Response, Increased Horsepower, and Increased Torque.
This is the first of its kind with Exact Control technology utilizing over 250 adjustment points that lock in place using a heavy duty stainless dual ball detent system. An extra long travel spring gives you superior range unmatched by any other manual boost controller while maintaining a high resolution, not some vague guess at where to set your boost. Don't trust the life of your engine to trial and error, rather pinpoint your setting using our rising scale running the length of the controller, lock and load. CNC’d from weapon’s grade 6061 Aluminum and laser etched our MBC will outlast your vehicle! The GrimmSpeed Manual Boost Controller redefines precise control and will promise you the results you demand.
We are bringing on the revolution, it's what you can expect from GrimmSpeed™
Will work with any OEM or Aftermarket turbo application.
1 - 3 of 3 Posts
