1 - 9 of 9 Posts
Offical MkIII Pushman
so been trying to figure out what the hell is going on, when ever im moving, there is a sound like the brakes are rubbing on roters. so took the wheel's off, and break pads are fine, i spin roters and i can hear the noise.
so i take the routers off, spin it, and the noise is still going on, but not as much. thought maybe something was dirty so i got some break cleaner and cleaned the piss out of them. still nada.
anything ealse to check? this is starting to piss me off.
also note, parking break is so lose wont even hold the car with the handel up, so thats not it.
i fail at english sorry. :(
dad checked the wheel bearing, not really sure how he did but he checked them.
it's the left and the right side.
also the rear diff doesnt make any sounds when in gear checked that as well :(
wheels are tight. for got what i set them to atm :/
your english is fine. according to my hanes manual "metallica grating sound consistent with vehicle speed" can be caused by pronounced wear in the universal joint bearings in the driveshaft. check that out. jack up the rear end, put the tranny in neutral, and spin the wheels, listen under the drive shaft to see if thats where it may be coming from
1 - 9 of 9 Posts
