1 - 4 of 4 Posts
Can someone give me a quick rundown of the engine bay grounds? Ive been having a misfire problem, and someone suggested to check my grounds first. However im not sure which grounds I may be missing.
The only one I honestly remember bolting up was the strap from the engine hook to the firewall. Im also reading about the strap from bellhousing to intake manifold, exactly where deos this go? Any more?
grounds
There are 5 grounds.
1 from the bellhousing to near the fuel filter
1 from the back of your haed to the firewall
2 on the side of your intake manifold
1 the main ground from your battery that connects to your block " drivers side "
Hope this helps
But if your haveing misfire problems I would check the gap on your plugs
make sure your coil packs are tight
Greg
1 - 4 of 4 Posts
