dunno if its the same but for my gt 4082, the fitting size was 16x1.25mm(may have been 1.5mm), to -6, then i used an adaptor from -6 to -4. You local hyraulic supply shop should carry it.
Here a picture of the darn hole.As you can see in the picture it has a tiny threaded hole in the center. I thought the GT BB series needed a 7/16-24 Iverted flare to bolt on directly to the turbine housing oil feed???
1 - 4 of 4 Posts
