1 - 1 of 1 Posts
hello I will keep this short. I have a ge motor being run on a gte ecu, with no turbo set up.
I would like to run na for a bit untill I am ready and feel the motor is reliable enough to add turbo. it's currently running rough and likely very rich. is there a way I can trick the ecu to run smoother.
again this is a ge vvti motor so the compression is capable of running na.
If your suggestion is a fcd and safc2 then any further info on how i would tune those to make this possible would be appreciated! thank you in advance for your time. if this is covered somewhere links would be appreciated.
1 - 1 of 1 Posts
