GTE Swap vs NA-T rebuild: What makes more sen$e?
1 reading
8.2K views 27 replies 12 participants last post by  Rezwalker
#1 ·
Due to engine issues (ultra low compression - 50lbs, oil leaks, etc etc), I finally gave up and am planning on swapping this summer.
For reference, I have a '98 2JZ-GE VVT-i (auto tranny)
I was fortunate enough to meet someone who has done 2JZ swaps in my area, and has good tuning experience as well.
I am presented with 3 options; I'm trying to figure out what makes more sense in terms of difficulty AND financially. I basically want the best bang for the buck:
1) Buy a low priced JDM 2JZ-GTE (~$1500-$1900) and do a direct swap. I know I need a harness and some other things. Also I was told I cannot use a 3" pipe because of the WG on those?
2) Keep the block and rebuild it and upgrade head + other parts to transform it in a real USDM GTE.
3) Keep the block and rebuild it and go NA-T (Also quick question: which electronics are compatible with VVT-i for NA-T again? AEM?)
I'm willing to spend between roughly $4k to $8k on parts and labour, and wish to end up between around 400hp to 600hp, I don't need more (not right now anyway). I want something reliable, so NA-T could be taken out, unless a full GTE rebuild is too expensive.
You guys' expertise and input will be greatly appreciated, and directly responsible for the revival of a Supra in desperate need :(
Thanks!!
/ Rez
#2 ·
im no expert in that field but ive seen a couple complete NA (2jzge) motors go for like 400-600 bucks. thats a pretty cheap fix if your just trying to get your car back on the road
#3 ·
Yeah that was another option I was looking at, but I'd still have to pull out this engine out and cost a few grands, so I'm taking this opportunity to go turbo. The car still runs, hey what'd you expect, it's a Toyota after all! ;)
#4 ·
You could also get the motor from Tiger for $1350. You don't need the harness because the wiring is almost identical. IIRC there are two sensors that are swapped and you can easily splice the wiring to the correction location.
I have a whole bunch of links to wiring diagrams, etc., from my 2JZGTE / S13 swap.
#19 ·
I see you are in Canada though,so if you find a complete GTE swap out there,go see it in person,make them compression test,leak down test it in front of u,then u would know for a fact you are getting a good,clean and healthy motor
i have been burned a few times by jdm suppliers in Canada,so now i am very cautious about them
#21 ·
Let me tell you how the XS turbo I had lasted me less than 2000 miles. LOL
I was waiting for it to blow up though. Its was a matter of time. I just put it on to drive the car. Now its just a matter of time till I get my adapter for my new turbo in and put that on along with my new wastegate! CANT WAIT!! Haha
#22 ·
GTE with single turbo off the classified section..
#23 ·
Yeah it's starting to look like that TonyN. I'm curious about a rough estimate on the parts list. I'm going to see the guy this week to see what I need... I'm assuming a new head, pistons, rods, cams, injector, fuel system, ecu, electronics, and the whole turbo kit ..... damn it's gonna cost quite a bit though! AAAAAaaaaahh...
#24 ·
It is cheaper, and you will have better results if you just go GTE swap. Are you looking to convert to a 6spd at the same time?
I am guessing that a 6spd & GTE conversion will cost you roughly 13-15k total if you did both at the same time; about 5-6k for the GTE swap.
#25 · (Edited)
thats just on parts though i think he was looking to spend 8k in total. you have to factor in the labor which will be a lot of money so to be honest he probably wont' be able to get the gte swap anyway.
with that amount of money you can go NA-T, built transmission and TT bottom and be good for 450whp.
and you can do most of the work yourself.
