1 - 13 of 13 Posts
This is my first attempt at doing this stuff, but I think it came out really good. I thought I would share what I used, and how I did this.
The stuff I used to fill the guage hole was PIG plastic repair. Its a compound you mash together for a minute till it turns all one color, and then you spread it over an area. It acts just like playdo. It starts to harden after 20 minutes, and its sandable/paintable after 3 hours...took a few attempts of layering this stuff to center the guage exacly where I wanted it. here are some pix. There are a few imperfections still I need to fix, and Its still not complete :bigthumb:
yah this crap is really rough unless you hit it hard with 100 grit for a while. It still needs some work, but the 2nd pic is sorta where I am headed. :bigthumb: Ill post pix of it in the car tommarow when It will be done
Republican
Just paint the stock needles to match! kinda hard to tell the quality... cause its a dark picture
I'm in the Death Business
1st picture = :freak:
2nd picture = very nice :bigthumb:
I was contemplating how to work in a new temp gauge, but I think I'm gonna steal a page out of Turkish's book and put a new gauge in the lighter spot
Hey, if you need any helps, thoughts, ideas just PM me and we can talk. :D
BTW, look around for my recent posts, and you'll find my "resume." ;)
i actually took apart a 2 5/8" guage and made it fit perfectly in the stock location, but the lighting was all ghetto and fucked up. So the only real way to get the lighting to work is to print out the guage so the numbers light up. I dont know how to even start with that...So I thought about just fitting the gauges in like a guage would slide in a cup. I think this is a little easier, and the guage lights up so you can see if your overheating at night! lol.
Discussion Starter · #11 · (Edited)
AJbiff said:
i'm thinking abought sheet meteling my guage cluster area and replace all the stock guages, with aftermarket ones.
would be expensive and alot of work to make it look clean...heres an example of what your probably thinking about...
EDIT: i think u have to be loged into SupraMania to see this pic since it was an atachment, but I hosted it so you can see...these are from a member on supramania, oneandgone
1 - 13 of 13 Posts
