Status
Not open for further replies.
1 - 9 of 9 Posts
Moderator
This is a guide (FAQ) for the Supraforums Car Audio and Alarms Forum.
Stock Speakers in a MKIV:
4" in the front, they are behind a 6.5" grille
6.5" in the rear
5x7 subwoofer located behind the rear seat (note: if you have am/fm tape headunit with NO cd player, you might not have a subwoofer).
The stock amplifier is located below the passanger seat.
It is rated at 30 watts into 4 channels + 50 watts x 1.
Note: these are max figures, most likely it is pusing 12-15 watts RMS x 4 + 20-25 watts RMS x 1.
Instructions for adding an alarm to a car with a Turbo Timer:
http://www.partydown.com/alarms/tt.jpg
Many Supra Subwoofer Installs:
http://briansbackyard.com/tmp/suprasubs/
Guide to Basic Car Audio Electronics:
http://www.bcae1.com/
JL Audio Amplifiers Tutorials
some great info with vids and pdf files at the link below.
click here for vids and pdf files
info they have
"Amplifier Tutorials (vids)
Interactive Parametric Equalizer Setting Tutorial
Macromedia Flash Player is required to view this tutorial
A parametric equalizer (like the one found on the 500/1 and 1000/1 amplifiers) is an extremely flexible tuning tool. This interactive tutorial explains this somewhat complex equalizer and allows the viewer to adjust its settings (virtually) and view the results.
Interactive Input Sensitivity (“Gain”) Setting Tutorial
Correctly adjusting the input sensitivity (gain) of the amplifier(s) in an audio system is one of the most important steps in the installation and tuning process. This crucial adjustment allows the amplifier to work in perfect harmony with a multitude of source units and speaker systems.
500/1, 1000/1: What the heck are all those switches and knobs for?
PDF file
500/1,1000/1: What the heck is a parametric equalizer?
PDF file
Amplifier Input Sensitivity ("Gain") Setting Guide
PDF file
SAMPLE SYSTEM LAYOUTS:
System 1: The Big, Bad Ford!
PDF file
System 2: Vicious Bass, Smoooth Mids, Sweeet Highs!
PDF file
System 3: 3-Way up front, H.O. in the back... can you say: "Tight"?
PDF file
System 4: Killer, budget-conscious system!
PDF file
System 5: "I don't care how it sounds... I JUST WANT BASS!"
PDF file
System 6: 5-channel flexibility on a budget.
PDF file
System 7: Drive four speaker systems from a 300/2.
PDF file
System 8: Audiophile Single-Subwoofer System.
PDF file
System 9: Compact sub... uncompromised sound quality.
PDF file
System 10: 3-Way up front... 3 subs in the back.
PDF file
System 11: Factory Upgrade... add a subwoofer.
PDF file
System 12: Huge Bass... No holds barred performance.
PDF file"
1 - 9 of 9 Posts
Status
