Well I am pulling my hair out on this one. I have a haltech PS2000 installed with a long harness in my s13. I can't get a crank sensor setup to work right. I went back to stock trigger wheel/sensor from my 60-2 wheel setup. That got me running but after getting some fuel settings correct I was getting a random buck/backfire when driving. It was always when I would be under throttle/load. Light or moderate. After doing some data logging I would see my rpm's would jump to 16,000. Crank sensor voltage would jump up as well. My filter level was set at 2. I tried 3 without any change. So I got a honeywell gt101 halleffect sensor and wired that up (really easy to do with the long harness) I would get rpm for the first 10-15 seconds cranking then it would go away. Some times it would start the car runs fine. One time it let me sit. But the car did run very good with the sensor for the short time It worked. I was scoping the crank senor this moring and the signal just goes away. So the sensor is faulty.
I just orderd a new toyota crank sensor. My question is would a bad crank sensor cause a spike like I was seeing or do they drop out? I am using the long harness so the trigger wires are sheiled and I have made sure they don't go near the large starter/alt wire.
