1 - 8 of 8 Posts
SuperWhiteNinetyTwoMeat
First of all the hatch latch lever will not pop open the hatch. So I tried to fix it. Now the hatch wont stay latched. It makes perfect contact and everything but it does not stay latched down. Any ideas on my hatch latch problem. Thanks.
It is lubed up pretty well and the first part of the latch wraps around it just fine but the other piece that is suppose to hold it secure just does not seem to be getting the job done. I think I am going to have to pull the tail lights and everything off to get to the bottom of this.
it's probably gummed up somewhere, or out of adjustment
also, check the cable to it, if it's still pulled tight it won't latch either...
THe cable is loose, I can here it clicking around when when I pull the lever put it does not do anything.
87Turbo said:
I had that problem on a '90. All i did was tilt it slightly left and it worked fine.
You mean the latch with the two bolts holding it down?
1 - 8 of 8 Posts
