21 - 39 of 39 Posts
Discussion Starter #26
good find!! however, i'm pretty sure that blue connector thing is power line for the factory key ring light. I find it interesting that it's causing starting issue...
by chance did you replace the bulb with LEDs?? I know i've changed mine to LED bulb a long time ago.. I will also give it a shot myself by disconnecting it to see if it'll fix the issue!
I’m stumped at why it caused it to be honest. The only thing I can think of is if the polarity is wrong. I’ve not touched the light it came over from Japan as it is. Certainly doesn’t seem bright enough for LED that’s for sure.
Discussion Starter #28
yeh that's what i plan on checking first, the polarity of the bulb... (if by disconnecting that connector solves my problem).
Thanks for the update though! really appreciate it.
Sorry guys, worst case of false hope ever. This did not cure my problem, I'm now really confused as to why it was turning first time in some cases, and not in others. Back to the drawing board.
damn that sucks... did you try looking into the starter? connectors? there was a post on facebook and people here suggested following/testing the wires. Other people had the same issue and replaced the starter and it fixed the issue. I will be back home next week and will put the car up on jacks to try to get to the starter and investigate.
Change your starter relay in the fusebox in the enginebay.. job done.
FIXED!! Finally had some time to look at this. Put car on jacks got to the starter everything looked ok no rust or corrosion anywhere. Contacts looked ok from what I saw. Then as "supra mkiv" suggested up top to change the starter relay in the fuse box.
Went to my local junk yard and grabbed a starter relay from an old Toyota car for a few bucks. Got home and swapped the relays out and car started up right away from the first try....Started the car few times today and started up on first try right away :)
Guess we can't overlook the small stuff! Hopefully its an easy fix for everyone having this issue as it was for me just to swap out the relays. Thanks again "supra mkiv".
My turn to try this, just got to find a starter relay somewhere in the UK. Don’t suppose anyone has a part number for it? Thanks to supralover93, supra mkiv and dus!
Inline for the win
If this was an issue I also suggest replacing the EFI 1 and 2 relays in the same fuse box. I seen a few cars shutoff because of these getting warm not to mention age.
DP
Can confirm, changing the starter relay worked perfectly, car now only takes one key turn to start, tested it about 10x today. Really chuffed this worked.
The one I replaced it with is purple, the one I took out is dark grey. The new part number is 28300-10020 if anyone needs it.
21 - 39 of 39 Posts
