Im rebuilding a 1999 2jz, from a gs300 and im in the process of choosing a headgasket. Im planning on boosting the engine and would like to get a thicker headgasket, (to lower compression) but whenever i look at their specs, it always says bore 87mm or 87.5. I didnt bore out my cylinders so theyre still at 86mm and im not sure if i can run these larger diameter headgaskets or do i need a 86mm one? If so if anyone could recomend smth id apreciate it.
From the land down under
Most of us who have gone down the NA-T path just buy an genuine Toyota GTE head gasket, as it suits most peoples set up
What are your power goals?
Im hoping for 500-700 daily car, i have gte pistons and rods so the compression is already lowerd i was hoping for like a 2 mm head gasket to get a compression of arround 8.5:1 but im not sure what is recomended for a boosted aplication.
Oh ok, I didn't realise that you had already installed GTE slugs in your block, as that makes a big difference to how you're best to approach things. A big part of your decision making will come down to what fuel you're planning to use, too.
I will link a thread below for you to read, that has alot of invaluable information in it, that is pertinent to what you're doing.
Go with 2jzge head gasket Do to the recess head dimension the compression should be spot on as the gte. Do not do a bigger head gasket. It will cause low response at low rpm. Everyone is running e85 on 10:1 compression or the latest Ge 10:5.1 with better low end response with max timing.
